Viet1982
Ok, I did something really stupid and regretful to my Prevail's screen. I know I'm gonna get some heat on here for doing what I did lol
Anyway, I had bought a pack of screen protectors and I kinda modified the installation instructions. I noticed how some other users said they used protectors that called for a few drops of water to make it easier to get the air bubbles out.
Well, I decided to use rubbing alcohol instead water thinking it would dry faster. Now the instructions on this set of protectors doesn't call for drops of water. Well about an hour after applying the protector I noticed what looked like something that was crystallizing on my screen.
I thought nothing about it and the next day it grew bigger. So I took it off and a chemical reaction between the alcohol and adhesive on the protector ate through the screen! It looked like super glue on plastic. So at this point I'm in panic mode and start to scratch off the build up on my screen and got most of the stuff off but now I got blemishes on my screen.
What I'm asking is does anyone know a way to buff out the remaining imperfection? Kinda like how people get those yellow headlights on their cars and then use a buffer to get it off. Or some kind of solvent to fill in the scratches?
It's not too bad, at least when the screen lights up I can barely see the scratches and blemishes. If push comes to shove I'll invest in another Prevail at the end of the year or hopefully Boost will churn out another Android phone by then.
Thanks.
