Root [MetaMorph] Circle Battery
droidkevlar
Android Expert
YOU MUST USE METAMORPH TO USE MY FILES. YOU CANNOT FLASH THIS VIA RECOVERY CONSOLE
Here are links for MM:
XML Version (better way to go) - MetaMorph v1.9.8.6 Application for Android | Themes
THM Version (older way) - MetaMorph v1.6.3 Application for Android | Themes
I made this since so many people requested just the circle battery. Enjoy!
I take no credit for making the circle battery. I only made the MM. If I knew who the OG creator of it was, I would give credit. So if that is you, please let me know and I will add your name to this.
Thanks to J-Woo for testing to make sure this worked and taking the screen shot.
You might have to apply the MM 2-4 times to have everything take effect. Dont know why, but it just does. Known issue.
As always, NAND before doing this as I am not responsible if this messes up your phone. I have included both THM and XML versions.
Download:
XML - Multiupload.com - upload your files to multiple file hosting sites!
THM - Multiupload.com - upload your files to multiple file hosting sites!
Screenshot:
Screenshot:
No worries...although over here I go by my real nickname, J-Dub...not available on XDA :)
And like I mentioned, the phone is charging, I took another shot in which it accurately portrays the charge in the circle. (I'll just have to figure out how to upload a pic or hope you take my word for it :) )
Hmmm...really tiny...sorry, but if you click on it, it's viewable.
hehe. Ya, i got that email but I liked the pic better with all green. Give ppl a better idea. But now they can see your attachment as well. And if you ever want to upload a pic like how I did, just use tinypic.com. It generates the code and all for you too.
Thanks again.
Thanks for this Kev!, anyway to get the number inside the circle battery I've seen that before and it's dank!!
Either use Kevlar Mash v3, which has like 10, 20, 40, 60, 80, 100 in it or use a CM ROM. Those ROMs allow you to use SpareParts and add that feature to it. Once I get a new sdcard since my old one died, I will be adding more to my theme. As I will be flashing to ELB, so things will get nice. I promise, lol.
Thanks for the response man, Keep up the hard work, it definitely is much appreciated!!!
Cool, looking forward to it being on ELB.
I'm back to running XTR and I just installed this circular battery. It's awesome! Thanks, Kevlar!
