D
Deleted User
Guest
Dont know if this is already posted but does metamorph work on velocity
Yes, Metamorphs should work on velocity 1.1
People have to make themes for it.
I wrote a proprietary variant of metamorph. Called velocitymorph. It is essentially the same thing but you have alot more control, where you can change fonts, boot animations, density, and more with a theme.
Themes are as always - Rom and Android version specific
We made some MM packages for older 2.1 roms, these will not work without modification on 2.2
If you find a MM that you like, i would gladly turn it into a VelocityMorph for you.
