Root metamorph on cyanogen
[quote="idroid";487084]Does metamorph work on cyanogen?[/quote]
Yes, but you need to find cyanogen compatible themes otherwise the framework (notification bar) will not theme. Below is a link to the theme section of Cyanogen but a google search will pull up other compatible themes. HexFusion is the best MM theme IMO (but I haven't tried it on 5.0.5.3). I'm running JRummy's remix which is not MM and NexTheme is another great non-MM theme...there are a few different ways you can go for getting you ROM themed.
CyanogenMod Forum -> Motorola Droid Themes
