andrizoid
Android Expert
Transparent Chaos!
This is a Metamorph theme that should work on ANY CyanogenMod rom.
It has been tested on the following
I love how the transparent widgets look. With my black wallpaper they looked even better, but since some widgets didnt come with a transparent skin, I made a few of my own with Andrizoids MM Builder. That was the beginning of this theme. Its all based around transparency or semi-transparency.
This is a pretty complete theme, it takes parts from the Nonsensikal Black theme, parts from the CyanogenTazz theme, and quite a few custom pieces.
Thanks go out to the creators of those two themes, Andrizoid for his awesome MetaMorph Builder, and all the other devs for their roms to run this on.
Also, in no particular order
-Ultra Lynx
-Daneshm90
Change Log
v2.1 DOWNLOAD HERE
v1.6 DOWNLOAD HERE
v1 DOWLOAD HERE
Screenshots!
Notes
If part of a theme doesnt take, make sure that you have the right app named the right way and installed in the right place.
If this gets to be a widely used theme, I can make an update zip to push the apps to the right spot and with the right name. Sort of a "setup" zip.
I TAKE REQUESTS!
If theres widget that you often use that you would like to see themed, let me know!
This is just the beginning, but I'm already running out of ideas, so give me some of yours!
Just to let you know, you will probably find it best to theme them one at a time. You will most likely get a reboot when applying it to the Google Search box and, of course, like most Metamorphs, it will require another reboot after you apply the framework-res. So don't freak out.
Code:
White Widow
Nonsensikal
CyanogenTazz
KaosFroyo
-Ultra Lynx
-Daneshm90
Change Log
v2.1 DOWNLOAD HERE
Code:
Pandora <--transparent; [B]the full app is copied to your sdcard. use a file manager to install it![/B]
Yr.No Weather <--transparent; ALL bgs are transparent for ALL widget sizes
MessagingWidgets <--updated theme
Added SIMPTEXT Icons from ULTRA LYNX
FancyWidget <--transparent bg; installed as Fancy_Widget.apk in /system/app
v1.6 DOWNLOAD HERE
Code:
Facebook Widget <--transparent and brightened the arrows; installed as Facebook.apk in /system/app
3Banana Notes Widget <--transparent; installed as 3BananaNotes.apk in /system/app
Youtube Widget <--transparent; installed as YouTube.apk in /system/app
v1 DOWLOAD HERE
Code:
Lockscreen <--transparent tabs and new icons
Status Bar BG <--semi transparent
Status Bar Icons <--cyanogentazz icons
Pull Down Notification Bar <--semi transparent with the android from nonsensikal black
Keyboard <--semi transparent keys
Font <--Russel Square font
Wallpaper <--black WP looks nice with transparent widgets
Settings Icons <--cyanogentazz settings icons
Power Control Widget <--transparent with white highlight
Genie Widget <--transparent
Google Search Widget <--transparent
Messaging Widgets <--must be installed as MessagingWidgets.apk in /system/app; only the
DARK skin is transparent
Screenshots!
Notes
I TAKE REQUESTS!
