Use the search link next to new posts at the top next time..can someone give me the link for metro off please
link to the metroFF w/o the roaming indicator:can someone give me the link for metro off please
http://techygeek.org/media/MetrOFF.v1.2-MMS-[GB]-[CM_AOSP]-No-Roaming-Off.zip
Ok so I flashed the metro off (used link provided by playful) and my MMS still doesnt work. Are there somekind of settings I need to change??
I, too have the same issue. I finally have CM7 installed correctly on both phones. No errors. Google Apps went on fine. MetrOff did go on fine. The problem is we still have no MMS. We have Wifi on, yes. Texting works fine. It's sending images that does not. Are there any manual settings we can fix?
