Root [MetroPCS/CDMA] Axis ROM for MetroPCS
william1964
Standard Disclaimer Your warranty is now void.
I am not responsible for bricked devices, dead SD cards, or any other issues that may arise from ignorance.
I was browsing the web to mine astonishment I found this ROM for MetroPCS galaxy s3.
Rom Review: Axis ROM Review for Galaxy S3! AT&T/T-Mobile/Verizon/Sprint/US Cellular/Metro PCS ~ Android Rootz | Source for Android Rooting, ROMS, Tricks and more!
WEBSITE: http://forum.xda-developers.com/showthread.php?t=1953008
New version RSL21:http://www.androidfilehost.com/?fid=22964708692722857
RSL20 ROM:http://forum.xda-developers.com/showthread.php?t=2089801
RSL19 ROM: http://www.androidfilehost.com/?fid=22946563261203078
Download ROM: http://www.androidfilehost.com/?fid=22946563261203254
Download Metro Fix: https://www.dropbox.com/s/b7bz524b56i006u/GOODNESS%2010.0.2%20TO%20METRO%20FIX.zip
leankernel: http://teamuscellular.com/Forum/top...kernel-jellybean-imoseyon-droidroidz-usc-v21/
Install ROM, Metro fix and Kernel at the same time.
Reboot and enjoy.
Thanks for this look like and nice rom :thumbup:
Have you try this yet? It doesn't have a separate link for the particular carrier weird.
Just try this rom ran the developers pick with the aroma no data for me :( but the rom was slick and fast my favorite once I get data :D
Same thing happened. To me but what I did was flash goodness metro fix and note it works but r only problem I have now is WiFi it won't allow me to turn it on so far this ROM is stupid fast lol
Now I try the latest update the one in the link is the prior version so with the metro fix it gives you data the rom felt like asop amazing I want to contact the developers for support for us
Thank you!
What is the flash that you are talking about though. Also with the flash does WiFi still work?
Yes WiFi works are you familiar with the goodness rom set up and flash instructions?
If not then is basically download the metro zip and kernel if you are not sure then don't do anything just yet
as edgee has the instructions in the goodness rom thread let me know
Where can i find the latest one?
