william1964
I flashed goodness jellybean 10.0.0 metro fix. Zip and I'm having none issues whatsoever with messaging![]()
same here no problem from day one....
It's funny I tried this on 2 phones. On one it is perfect. One the second when I try to send MMS I get a server error. And I followed the exact same steps.
I can't get tethering to work. ....
Go figure thetering work fine for me lol
The one built in?
The 19 built
Lmao my bad didn't read right yes the one built in thought you meant the built number lol I'm on built 19![]()
i flashed the metro fix from the goodness thread and have not experienced this problem at all. this is my new favorite ROM i will be using this for awhile. battery life is much better than Goodness and have not had any bugs yet.Guys does unchecking the group messaging option in the messaging setting fixes the new thread problem?
i flashed the rom and made sure not to let it boot. then flashed metro fix, then latest lean kernel for usc 2.1Let me ask you the install process you used
Rom - metro fix - kernel once you were done with the installation did you let the rom boot or you did it went back to the install to flash the fix and kernel?
also here are some nice themes already ported over
Chromium theme
Chromiumfree - Download - 4shared - alexandre nicolas
Liquid Blue by Annex1
Dev-Host - liquid blue.apk - The Ultimate Free File Hosting / File Sharing Service
Betterbean cyan thanks to Blackout1911
Dev-Host - betterbean cyan.apk - The Ultimate Free File Hosting / File Sharing Service
Betterbean Red
Dev-Host - betterbean red.apk - The Ultimate Free File Hosting / File Sharing Service
Blackedout
Dev-Host - blacked out.apk - The Ultimate Free File Hosting / File Sharing Service
Royal elegance
Dev-Host - royal elegance.apk - The Ultimate Free File Hosting / File Sharing Service
Bluealpha
http://forum.xda-developers.com/attachment.php?attachmentid=1927359&d=1367415725
Vivid theme
http://forum.xda-developers.com/attachment.php?attachmentid=1932673&d=1367598522
go to system settings, then tweaks, then advanced, then xposed framework, then framework installer, then click install/update. once that is complete reboot phone. once that is installed you can download and install the themes like a normal apk. then so back to system settings, then tweaks, then advanced xposed framework, then theme manager. after that you can select your desired theme click apply and reboot.
Hmm. I did all of that and I see no difference???
Everything is exactly the same.
Using Liquid Blue
Weird did you reboot? It does not change everything but you should noticed some differences. I am using vivid and it makes my settings menu look awesome. Also changes My icons and notification bar
no problem man let me know the results hope it helps you
