Root [MetroPCS/CDMA] Axis ROM for MetroPCS
I KNEW IVE SEEN THIS THREAD POSTED BEFORE I JUST COULDNT GET MY FINGER ON IT
This is the thread here http://androidforums.com/metropcs-g...d-_-simple-elegant-brilliant.html#post5816584
after some time the rom was renamed to AXIS
When I saw this thread was posted I was like "theres already a thread on this rom" then i saw all the comments proving otherwise so I just left it alone.
GalaxyRom = AXIS Rom
Should the threads be merged?
But I tried galaxyrom when it was first released and I loved the look. I dont know if they still use that black and white feel but it was pretty cool.
Meh looks cool but im hooked on Metropolis.Would be cool to integrate all those locksreens on Metropolis.Shabby are you reading this? Lol
The ICS messaging app crashes so don't use it
I love the ROM a lot its like AOSP with TOUCHWIZ
now then is their any way to remove the earphone app page when you plug earphones in?
Yeah if you customize your apps and setting don't include the aosp msg and just flash the 10.0.2 metro fix and it works fine msg WiFi data everything
My messaging is working but now my long SMS won't split or convert. MMS to a person goes to a new message thread.
I remember this happening on another ROM and was fixed shortly after.
Yep, I'm having that problem too.
Long time no chat johnny, bro I found out its going to group chat, you start the download in the normal txt thread and once its downloaded it moves it to group, I know for a fact we had this issue before on another rom i forget which one I guess I will be on a search for it
