Root [MetroPCS/CDMA] Axis ROM for MetroPCS
well after taking a deeper look lol this thing is pretty intense.. loaded up the ying yang with tweaks... lol not even sure what I can do here.. haha this is a amazing rom I must say.. this developer has earned his title without a doubt!!
themes are in tweaks > advanced > xposed
as for the lockscreen torch I dont believe its implemented in this rom.
On a somehwhat related note. Anyone know if morphology will work for this rom?
i got 5 bucks says that yall cant beat my score on my rom :D
I came pretty close
OK I downloaded build 19 and the 10.0.2 metro fix but I'm still having issues with messaging and I did pick the aosp messaging what should I do?
I think the problem is that you DID pick aosp msg. I dont think you're supposed to.. well i didnt anyway
The Goodness 10.0.2 fix zip overwrite the Aosp mms. Thus making it non usable. You have to use the normal mms. I've brought this to the Devs attention and he said he'll try to fix it for the next build
yes .... flashing deviantXone wil fix everything ;]
jkjk. did you flash the goodness metro fix 10.0.02 fix??
Yup I did but still no go.I got to fix the wifi by flashing shabbys kernel.Anyways I went back to metropolis.Had to many reebots in los than 2hrs.
Edit:Back on this ROM again.Decided to give it another try everything great so far but still cant get mms to work.
New update was supposed to fix the accounts not showing.I'm still not able to see them.Is it just me?
Sent from my SCH-R530M using Tapatalk 2
So I had installed rsl20 and chose developers pick. Flash the fix plus kernel and everything worked. Or so I thought. This morning I realized my mms didn't work when someone was trying to send me a pic. Nor could I send. So I flashed the new build once with aosp and once without it. Both times I couldn't even open messaging. I gave up and just flashed rsl20 again and everything worked fine, except for mms of course. Strange thing is only aosp worked. I tried the regular messaging app on the rsl20 but that would crash as well. Any ideas to get my mms working?
install latest using custome and DON'T choose aosp messaging, kernel, goodness fix, and then this http://www.shabbypenguin.com/OUDstuff/Samsung/Metro/R530M/Metropolis/Metropolis-MMS.zip
if you get a server error then you are out of luck your s3 is like my wife's no matter what i do mms doesn't work
