Root [MetroPCS/CDMA] Cant call or text help.
darryim
I have the Nightlies ROM everything was working good but den today idk what happened now i cant call or text i cant recive ither but i still have 4g idk whats going on any help guys ?? thank you .
EDIT. " SOLVED"
Have you try the other roms never had that problem issue with neither roms can you try re flashing and see
i did everything but when i try to restore the metro back stock backup it gives me a error saying MD5
mispatch :(
I'm guessing is because you're are trying to restore a twrp backup with cwm. You should have your own stock backup that you made with cwm. If you didn't make a backup then you will need to install goomanager from the playstore and flash twrp in order to restore that stock backup.
Or check under Settings -> Network (or something like it)
Make sure everything looks sound. (the radio type, the network is set to Automatic...)
Messed-up settings may be at the heart of all that bs... That's my current theory, at least.
I never had this problem, so I can't diagnose it, but I'm thinking some settings database file must be getting scrambled randomly across some flashes...
well i have clockworkmod recovery touch thats how im trying to restore the back up?? what exacly is twrp??
i already check those settings nothing is helping omg.
First off delete that picture. It shows your meid info which you should NEVER share. People can use it to clone your phone.
Twrp is a recovery like cwm. The stock file you downloaded was made using twrp so it won't work with cwm. Follow the directions in my last post to flash twrp so you can be cool like the rest of us. Oh and so you can restore that backup too.
sorry sir will do that . any idea on how do i install Twrp tru goomanager ??
i have the app already .
Yeah just tap your phones menu key from the main menu in goomanager and choose install recoveryscript. You should be on wifi because 4g will make it loops sometimes with a invalid md5 message.
oh ok did that now im trying to put the stock rom i downloaded in the TWRP folder when i connect it to my pc but the Twrp forlder is NOT there ...
You can create the folder yourself but i would suggest you let twrp do it. To do that boot into recovery and choose backup. Let it backup your system and all the folders will be made for you.
Did the back up conected the phone to pc tried to look for the Twrp folder in Ex SD but is not there is in Internal memory . shud it still work if i do it from there?
Yes. Pretty much everything is saved to your internal by default. It will work. Don't forget to unzip thay backup you downloaded forst before placing in your backup folder.
oh but i cant see my backup folder and the backup that i ust made in that TWRP folder . weird ...
edit ..i can see the backup wen i go into recovery restore thow ..
Do you mean you can't see it from your pc? Do you have a file manager installed on your phone? I like solid explorer from the playstore. You use that to copy it to your backup folder.
ok my friend im back to stock NOW ima try your anycut method to restore my ratio ....
ok i did the anycut method after iwent back to stock rooted http://androidforums.com/metropcs-g...775-stock-odin-tar-return-stock-non-root.html
post # 41 den i just used this anycut method to restore my ratio info so i can make calls again and text it all worked THANK YOU airtioteclint FOR your help man .
for anybody that messed up their phone please i would recomend to try all this methods before returning to metro , they work for any question just ask me .
Glad to see you figure it out airtioteclint did an excellent job helping you out :thumbup:
ok i did the anycut method after iwent back to stock rooted http://androidforums.com/metropcs-galaxy-s3-all-things-root/637775-stock-odin-tar-return-stock-non-root.html
Cool. Glad to hear it. :)
