Hellion420
Member
Im not sure, but i have a buy on craiglist from a guy whos selling one, but its from sprint, is it even possible to use the 4g for metro, even though its not technically from metro?
dunno if they will issue/sell you a uicc card or not.lol and i doubt theres a way to bypass that, much less to even get one from metro?
i figured , but i wanted to know, metro wants 500 for it and im not willing to pay that much!
oh dont they just suck! lolGman he's buying a used one. Sprint won't work because their UICC/SIM card is embedded in the phone.
also u can use straight talk with unlocked gsm phones. been seeing their good plans lately. sprint and verizon and metro are not gsm.
Find a used T-mo one, that will work and port over to metro just fine.
How would you port the T-mobile one over to metro??
You can go to a METRO dealer and they can flash it over to metro for you everything works good.
I called technical support for metro pcs. Gave them my model number and they said they couldn't do it. Are you positive it works for T-mobile phones?
I'm positive bro dont call metro technical support go to any metro authorized dealer where they flash phones don't go to the cooperate office and I promise you they will be able to flash it to METRO my buddie has he's T-Mobile s3 flash to METRO.
With lte ?
i dont believe the tmobile version has LTE?
at least its not advertised since tmo doesn't have an lte network, its all hspa+
what mrpnut posted, it does work if you buy it used/traded T-Mobile S3 will work wonder with MetroPCS, done it and one of my buddy did the same work wonder
With working 4g only porting of the s3 or any other phone only network data is 3g everything works but no lte if lte is working I wanna speak to the owner of it
When I get a chance I'm going to his house and gonna takes some pic of his t mobile flash to METRO and everything working it even showing the 4g icon.
