haxmethod
my s3 is getting hot still and i want to know if these temperatures are normal
i messed around a lot with the voltage control with the faux kernel on aokp but since then i've tried every rom and kernel combo, right now i'm blackbean with linaro and its still getting crazy hot.
i took it to a corporate store and they said they can't do anything about it unless see it doing anything crazy. I'm at wits end I'm thinking about bricking it so they'll replace but I'm not sure if they will so i don't want to risk it.
