Where is the update?
If I've already installed frandom lean kernel...do I still need to install crossbreeder...
Yes, it works with the kernel. Its pretty darn good
Sorry to hear that. There shouldn't be any leftover from the mod. Some things just doesn't work with all phones. Wipe cache/dalvikl that should reset it
How do you know the effects are still there? ok, go into the xda forum & follow his instructions on how to turn it off using the terminal emulator.
The effects like no animations are still there...and when I typed the command it said no file or directory found...I typed it in correctly...
go into your settings & into developer options to turn back on animations. If it said no file, then it was removed when you flashed the zip
If I remember right the default setting is 1. But I turn mine off on any rom I use. For me everything switches quicker
CrossBreeder updated 6.16.13v3 and bms kernel updated 3.4.49.
Is there a way to take advantage of this without flashing the kernel
Yes. The only thing the kernel provide is frandom support. Thats only part of the mod. You will still get dns, tether, adblock and smoother scrolling from just flashing crossbreeder alone.![]()
Cool that is what I will do for some reason my phone doesn't like other kernels lol I was reading into it does not look difficult to flash the CrossBreeder
Really? That sucks. I love the kernels we have available. I'm always switching from lean to bms depending on whichever is newer. Lol
