ACrappyDJ
Member
Just to be sure, lol I forgot which kernel to flash. Its the vzw/usc right?
That is correct. Flash, wipe dalvic/cache, and fix permissions, you're good to go!
That is correct. Flash, wipe dalvic/cache, and fix permissions, you're good to go!![]()
Just a quick lil note for those who still you use this mod & kernel. the updated kernel for 2013701 is messed up. I get constant reboots & other apps are not working right. crossbreeder seems to be ok though. that I still recommend. but if you like the frandom/bms kernel like I do I would stay with 20130630 build.
Their thread won't let me post any problems, so hopefully someone who can get through will read this one
I've been using bms 7/1 since release with no issues. I do not remember a 6/30 release?? I believe the last one before that was father's day. 6/17.
lol yeah you're right lol. got my numbers all mixed up. I'm back using the 6/16 kernel. it's the 7/02 mod that's been causing slow downs also. but the 7/01 kernel has been causing me problems too. So I'll wait for the next build all around. but I still think this mod & bms are a great combo.
Should I just download the 7/01 BMS build or an older one?...jtw stated it was kinda unstable ish...
Um... should I flash the frandom zip alongside the BMS kernel...I can't tell if it's necessary or if
Its just for testing...
I always wondered the same thing, but I think it's just for testing.
