Root [MetroPCS/CDMA] [OUDHS] CM10 Alpha 0.0.6
Status
Not open for further replies.
Ouch. I would have been pissed downloading something that big only to discover it doesn't work. Oh well at least he got your help. But he would need twrp. Can it be installed with odin? I did it through goomanager.
Yes flashing TWRP will install using Odin.
i tried testing it and it failed on odin using pda, but my backup is still uploading. ;)
What do you mean by failed?
Did Odin fail half way through? Did it finish and say fail?
Or did it not open at all? Depending on which, this may help me see what's the dilio...
it failed on the spot, within 10 sec after i hit the button.
Couldnt get google now to work...did find another google now that didnt force cl ose but the search feature dont work.
Status
