Root [MetroPCS/CDMA] [ROM][4.4.2][Weekly] SlimKat-d2lte [5.6]
They have zips to change the framework and stuff but I asked about it never heard back because I tried flashing them but nothing changed
Theming by itself does not work yet. Xposed might. Slim essentially comes pre-themed with their TRDS. The Real Dark Slim. Fresh install is always recommended because of their theming with Google apps and other apps. If you don't like TRDS, the enhancements or the DPI I would recommend Metropolis or #2 for Samsung base or one of the myriad of other AOSP based ROMs
Not me I'm still on stable thought about coming weekly updates but noticed the difference in build numbers
Anybody try out the new unified build? Let me know what you think!!
Works well but I had to change settings to get data working correctly. I used the advice in the CM thread to change it. Go to the mobile networks setting and change CDMA subscription to NV.
Damn it feel free to slap me I will get this corrected in the next build...
I believe it's a problem with CM also. Roaming was automatically switched on and it looked like it was giving me service but roaming so I quickly turned that off as well.
As much as I would like to place the blame on them its all a missed edit to the init file I missed or I should say forgot.
Working great right out of the box , LTE pops right on now, running fast and smooth.
Maybe a problem with MMS or might just be my phone , I couldn't send or receive MMS so I grabbed MMS apk out of the last slim ROM and its back working.
Wipe everything even system then reinstall , maybe a corrupt download try to redownload , wipe everything then reinstall.
Can confirm MMS is not working. Instead of receiving the message I get a error message and it shows a blank message as a draft
Is it just me or the D2MTR is no longer in Slimroms.net supported devices list? Is the D2LTE made for Metropcs CDMA Galaxy S3??
I did a clean install of the latest build (formatted system, etc.). The ROM won't display "MetroPCS" as my carrier. Instead it says "Roaming Indicator Off". Anyone know what this means and how to fix it?
First time flashing a unified d2lte build, btw.
