Root [MetroPCS/CDMA] [ROM][4.4.2][Weekly] SlimKat-d2lte [5.6]
There is some differences in my init file compared to cms. Can anyone clean flash latest cm build n confirm if all works n displays correctly?
I tried flashing the latest CM unified builds three times, but it corrupted my data (phone number, min, mdn, prl, etc) each time. It's an occasional bug that I've encountered in the past with CM (4.2, 4.3). But now it's constant with their unified builds.
Okay, so I looked into the "Roaming Indicator Off" issue and apparently its not uncommon for it to appear in unified builds for any device. The good thing is that it's superficial; it doesn't have any effect on signal, calls, text, data, etc. The ROM can identify the carrier of the device, but it can't display it.
As for the MMS issue, I used Get@Me's mms_config.xml to fix it. MMS is working perfectly now.
As always, this ROM is incredibly fast and stable. I especially like the Recent Apps feature. Thanks for the continued support, Nick.
It is uncommon for my builds lol I can fix it just need someone to work with me and be able to flash multiple clean installs. If anyone is up for it email me nicklovell23@gmail.com
