Root [MetroPCS/CDMA] [ROM][4.4.2][Weekly] SlimKat-d2lte [5.6]
exactly. Anyway they don't show up on goo nor their website. am I asking too much if you can kindly pass me the link on here?
It won't be on the site because we weren't official. Goomanager has the latest publicly available 4.3 and has been posted. I delete old ROMs so I don't have it.
2.8 RC3 came out yesterday. It added some great features like the new SlimPie and the Google Open Source Dialer which looks/sounds great. Thanks to Nick and the Slimteam!
Loving this still. New features are functioning very well. I use the status bar alerts and the recent apps functionality/speed is great for multitasking!
This ROM takes some getting used to due to everything being smaller but had to have something other than stock that had more than LTE due to network going from great to barely any LTE anywhere off main roads now have to rely on 3g 1x when working it sux but rom works great
Yes it's the same for me too everything is smaller I checked in setting interface but there is no option to make bigger or adjust that rather than that everything works fine and I love this ROM is there anyway to fix that? The last 5 or 6 built have same problem. Please fix or let us how to adjust.
Change the DPI or download xposed framework and add some modules to modify the DPI of the apps you think are to small :) simple easy fix for me and a whole lot more customization with no sacrifices
It's not just some apps everything is smaller and there is no DPI option or I couldn't find it no where in setting interface.
They said they are looking into adding the option to change in a future update but they give a link to an app in play store just have to go to slimcenter /slimota/ FAQ the DPI question is there and the link I haven't tried the app cause im liking the smaller size
Any1 now if their framework zips for theming still work on the ROM I flashed them but still just black and white
You can always edit the build prop to change the DPI. I like it the way it is and is the main reason I have been running Slim for a long time.
Been so long since I flashed a rom I forgot. Which version is compatible with our phone? Is it international or us cellular
So I got this working but 2 things. How can I change the size of everything (too small) and how can I get the home button to work. I've set it up in settings but it still does nothing when I press it
It also seems that I've lost root.
Use an app in app store to change DPI they said they r working on it a few posts back I put how to find the app to change things not sure about home button I had that happen once but reboot fixed it and u have to change root settings in settings I have to find out where that setting is again and will post back I'm not finding it but its an the many setting it will b set to not rooted or something like that
OK its under developer options and that's hidden so go to build number keep tapping until small pop up says its enabled and root access will b there in developer options
OK another question. Does this rom support the 4 way reboot zip. So I can boot to recovery from the power menu?
