The usual 2-3 minutes
I've dirty flashed every update..
dirty flash is when you dont wipe data and cache right ? but then idk why ur batt drained so much
Yea which there it no reason to do so when the update isn't major. Yea and I'm noticing that my battery is taking forever to charge.
Yea probably. I'm buying an extended one today probably.
Well I'm buying the battery regardlessand well I've been running cyanogen mod for about 2 months now.
No I meant your battery problem was sudden. Didn't it just happen with the last build? Try restoring a backup if you have one or reflashing. I flashed latest last night with no battery problems so far btw.
On another note when 4.2.2 gets commited it will still be cm10.1 right? Anybody?
I will say so I read the actual changes are minor wouldn't be worth changing to like 10.2 that's what I think
How do I install this?![]()
Hola hermanos y hermanas,
I decided that tw is too cluttered for my taste at the moment and ide like to flash cm10.1
However, im not really sure where to find the mms apk from bb7. If anyone would direct me, that would be spiffy. Im gonna keep looking though (i dont want to search for it by flashing it myself :[ mad work
Gracias![]()
I'm so sorry if this has been answered but how do I get the playstore? I tried downloading the apk off the internet but it keeps closing everytime I run it.
How do i return to Cm 10.1 , I currently have JellyBean GooNess but i dont like it at all i just wanted the multi view. To flash JB GoodNess i had to flash a kernel , do i need to flash another one to go back to Cm 10.1 , or go back to complete stock everything and start the procceses all over again (e.x return to stock , flash CWM , root, Flash cm10.1)
