Is anybody try cm? I didn't update for the last a week and two b/c of 4G not working, if anyone tried it can let me know which one is working, please I'm still on RC-4.
I'm on the latest nightly, and 4g is working fine for me.
Which cm did you flash? Cm10? CM10.1? Gotta let us know because I think you flashed the wrong gapps. You will need 4.1 gapps for cm10 and 4.2.2 gapps for any recent cm10.1
I have downloaded 6 gapp packages that said they were made for 4.2.2 and would work on cm 10.1.0 and it hasnt fixed the problem. Could anyone point me in the right direction or perhaps link me to the gapps pack that they used and worked? Sorry for the multiple posts, Ive just been at this for hours and my brain is tired. Is there something I could possibly be doing wrong?
Thanks for any help ahead of time
It looks like the gapps is right. Maybe it's the nightly? I've been using liquid smooth so i can't verify but you might want to try the stable release.
CyanogenMod Downloads
Yeah, I actually found it was a common problem with the rom.. I found one fix that worked.. but he had a verizon phone. I spent 30 minutes trying to get by the captcha on XDA before I lost it hahaha So I'll ask you.
Threres a fix here :
http://forum.xda-developers.com/showthread.php?p=42940896
(4th reply I think)
Is flashing that a no-no since its verizon? If it is, or you dont know.. Ill just flash the stable
Well I'm no developer (Shabbypenquin that's Shabbypenquin) but i took a look inside that zip and it looks modem related. So i definitely would not flash it.
Not sure if the issue was fixed in stable so why not just try liquid smooth, or illusion rom? They're tried, tested and trued by a lot of us.
Hahaha I actually had a message half typed to shabby when you answered. Ive heard a lot about liquid but I honestly get afraid of snatching roms not in the allthingsroot thread. If could link me to a download, that'd be cool.
Thanks for all your help!
so anyone run the stable yet? hows it workin?
hello hey just wanna ask how did you fix that error? i just flashed cm 10.1 and same error is happening google gabbs stopped i flashed same version 2.1.2 and i keep getting that error. any help will be really apreciated thanks!!Thanks, I actually looked over the files I was flashing and the gapps that were old. Thanks, I appreciate the quick replies.
