CyanogenMod is a free, community built, aftermarket firmware distribution of Android 4.1 (Jelly Bean), which is designed to increase performance and reliability over stock Android for your device.
Code:
#include
* Your warranty is now void.
* We are not responsible for bricked devices, dead SD cards,
* thermonuclear war, or you getting fired because the alarm app failed. Please
* do some research if you have any concerns about features included in this ROM
* before flashing it! YOU are choosing to make these modifications, and if
* you point the finger at me for messing up your device, I will laugh at you.
All the source code for CyanogenMod is available in the CyanogenMod
Github repo. And if you would like to contribute to CyanogenMod, please visit out
Gerrit Code Review
Instructions:
First time flashing CyanogenMod 10 your device, or coming from another ROM?
- Root the device and install ClockworkMod Recovery.e.
- Perform a NANDroid backup of your current ROM.
- Format the system, data & cache partitions of your device.
- Perform a factory reset.
- Flash CyanogenMod.
Do not use bug tracker if they are nightly builds.
Download Links:
CyanogenMod Downloads
MD5Sum: check the md5 under the files named associate with your build version before flashing it
Changelogs:
BBQLog - Official CyanogenMod 7, 9 and 10 Changelog for Android distrubtion
CM10 Nightlies Changelogs
The CyanogenMod team would like to thank
everyone involved in helping with testing, coding, debugging & documenting! Enjoy!
