Does anybody know if mms will work on Handscend or Go Sms, with this rom?
pg and a few others recommended if u did since mms has not been fixed yet.
Just tried Handscend, that didn't work, going to try go sms now.
You have to explicitly select mms service in go sms. It's at the bottom of the settings page, in red.
Go to important tips and tick on "stock mms (sms?) uninstalled"
also turn off notification on stock.![]()
Okay, I found this setting and applied it.
Also did this, still not working for me, are you guys actually using this fix, if so I can't figure out what I'm doing wrong! :banghead::banghead:
Update didn't fix MMS ....
Gerrit Code Review
there hasnt been any updates(there was a new nightly, but nothing pushed to cm's stuff ergo nothing changed except the base cm10 code)
i read the logs im aware of the changes or this case no changes but i was simply letting every1 know that new release does not fix mms.Gerrit Code Review
i know you know man lol, i was explaining to everyone else who doesnt follow the stuff![]()
You have working mms??? With go sms?![]()
Haha if u can get MMS working on bb I'll switch over in a heart beat even though I was thinking of switching over anyways lol
yes
try it, you will like it i backup both and switch every 6 hours if that makes sense. lol
Hey nuttmeg I've tried all the instructions earlier in this post and can't get my mms to work, can you please tell me exactly what you did to get yours to work... please!
i just downloaded go sms pro and open it and tap on running mode and make sure it's on pro mode, than i went to advance and set everything to my liking like ringtones and all, than i sent a pic message to my other phone and it work. Than i went to default messaging app and disable the notification and auto retrieve.
Thanks for your reply and help nuttmeg, I followed your instructions and am now able to receive mms messages, but I'm still having issues with sending them (some go out and some just hang on sending mode,don't know what's up with that) but at least I can receive them and I am grateful for that, thanks for all your help on the forum!![]()
