So...i know about that warning to reset Wallet before flashing a rom to avoid nfc damage...but could i just remove the app?
Thanks for the response man, appreciate it. And yeah using it probably makes ypu look infintiely cooler =p... so basically removing it is not harmful?Yes you can. I personally use Wallet every chance I get. Never though I would have but I can't resist the expression on people's faces when I use it. "Dat boy got the devil inside him"
it sucked back when it was just the prepaid one, but sinc ei can have my paypal card on there i use it where ever i can
and yes you can remove it![]()
wallet on my phone says something about my phone being modified.....how do I bypass that?
If you don't reset it will it ruin it permanently? I didn't read about this before I flashed
