Downloads:
Choose a Firmware from here:
MetroPCS: MS50010i_00.kdz
Programs to convert and flash firmware: KDZ_FW_UPD_EN.zip
Device drivers: LGUnitedMobileDriver_S50MAN310AP22_ML_WHQL_Ver_3.1 0.1.exe
How to get into emergency mode:
Powered off the phone, press and hold volume up and connected the usb cable.
To get out of e-mode, pull battery (do not do this while flashing firmware!)
Picture of emergency mode (Thanks to dschach):
Before flashing firmware, please make sure your battery is well charged. Flashing does not charge your phone, and flashing can take up to 30 minutes.
Instructions:
1. Install phone drivers (phone drivers may already be installed so skip if your computer reads your phone)
2. Install msxml.msi
3. Disable antivirus software
4. If the file you downloaded ends in KDZ, skip to step 12
5. Open UpTestEX_mod2_marwin.exe
6. Wait for the program to open
6. Look for "Encrypt cab file to kdz file"
8. Click the folder icon
9. Choose the location of the cab you downloaded for LGVM720 firmware
10. Encrypt cab -> kdz Program will freeze up. DO NOT EXIT until program says Done!!! Otherwise it won't finish converting.
11. Close program
12. Open KDZ_FW_UPD.exe
13. "Type" choose 3GQCT
14. Choose in "Phonemode": Emergency
15. Click the folder icon and choose the kdz file that UpTestEX_mod2_marwin.exe just made.
16. Click Launch software update and enjoy!
If you are stuck in a bootloop, do this (it will factory reset by following this):
Quote:
Originally Posted by Sepero
Take out your battery. Put it back in. Power on your phone holding Power+Vol Down.
Source: [GUIDE] Unbrick OR Unroot LG Motion 4G [KDZ]
Thanks to: please thank sammyz and duper1 who posted the method here.
Instructions:
11. Close program
