Root [MetroPCS] Stock rom 2
Hey guyys i need some help im new to all this but is there a way to go back to stock ROM with out using a PC like can I install it on my recovery just like I did the ROMs
If you wanna do that...then the closest your gonna get is gametheorys ROM or Bards ROM. Both are flashable. And stock. But both are unique as well.
Check your p/m s.
This can be done but it is almost futile to do with out a pc.
You'll need Three hours and a huge sd card to do it, just to Start.
The zipped recovery on a stock f6 is over 700 mb minimum.
Its easier if you borrow the use of someone's pc to do it.
EDIT: 2014-04-20.00.04.20
This has gotten a few people started again by the amount of times it was D/L'd. Maybe it CAN help.
