Root [MetroPCS & T-Mobile] Disable vibration and wifi calling pop-up?
Whyzor
Android Expert
After rooting this phone I still can't figure out a couple of annoyances.
1) Disable vibration completely, even if it's disabled in settings, some apps don't obey it and vibrate (talkatone for example on incoming ring & dialing digits). In other phones I can just run as 'su' then
'chmod 444 /sys/class/timed_output/vibrator/enable'. But that path doesn't exist on the F3. Any other ideas?
2) Everytime I connect on wifi, there's a pop-up telling me about MetroPCS wifi calling, I can skip to dismiss it or 'learn more', which is just another couple pages of instructions, but doesn't do anything else. It keeps reappearing no matter which option I select. (Same with airplane mode, but I can live with that somewhat).
UPDATE: #2 is resolved by disabling the "IPService" in the Settings - Apps - All tab.
Settings>Call wifi calling should be at the bottom.
That was already disabled, since I use Talkatone & Google Voice for Wifi calling, have no need for the built-in one, which only works with MetroPCS SIM cards anyway (I have T-Mobile). I got this issue resolved by disabling the "IPService" in the Settings - Apps - All tab.
I use the T-mo wifi calling and it is lovely .. no banner adds (talkatone) ... I really need Google to get off their bum and finaly built in voip into gvoice.
You can try flashing the t-mobile firmware then. I have a metro f3 on t-mobile firmware. (long story)
The popup is gone now, so there's no need. It seems TMobile firmware has more adware built-in also (that I had to remove after rooting)
I use TMobile prepaid, so their wifi calling won't work anyway. I'm mostly forwarding via Google Voice to another landline or on wifi, so only actually use their carrier data/minutes occasionally. I heard Hangouts will integrate Google Voice for VoIP eventually, it's already available on the iOS.
