help would be very appreciatedThe fastest way is by using Android Tuner n on the task tap / click on kernel botton (bottom right penguin ) look for system/bin/hostapd file .... click on it n kill itAnyway that the WiFi app doesn't take ages to accept a device. I know on the computer it's take a very long time for it to connect is there a way to speed it up for the ps4? Cause after 15 seconds it says it did not connect in time. I've done everything it says here and still doesn't connect.help would be very appreciated
I found a way to get past that.Dude it worked but... git the metro hotspot thing. Lol man so close!
You need to use a vpn on your phone and it will bypass the metropcs block page.
I think most of the vpns in the Google Play store should work.
Surfeasy vpn seems to work for me.Ok i went ahead and did the other steps i got vpn unlimited from google play but the tethering only works good on my other android phones i still cant use it on my ps3 or laptop, they connect just fine to wifi just cant go online, any suggestions on a new vpn app or other setting changes i should use??
Used ur guide for mpcs f3. Worked great!How all doing.... Please post.. Results if u had use any of the guides...it wll help the community.
Man reindeer is great. CrossVPN is good too when the reindeer train ends.
It doesn't have a time limit?
As it appears, I have successfully connected my PS4 onto my phone with no trouble. All you have to do is accept it on the Access Control log. Hope that helps! I'm not too sure about the PS3, but I think they use the same protocol.
And it's free to boot!
