Get upgrade error on metropcs.. WParam: 100 and LParam: 64 Then I click ok and it shows WParam: 100 and LParam: 0
I also included the log:
[R&D Test Tools Log File]
16:42:22 : Launching SW update
16:42:22 : Unpacking KDZ
16:42:30 : KDZ file extraced
16:42:34 : Files were extracted.
16:42:34 : LGMobileDL Load.
16:42:34 : Port = -1
16:42:34 : Connecting to phone
16:42:49 : Check Phone mode = 2
16:42:49 : Phone type check.......
16:42:50 : LGMobileDL.DLL Loading....
16:42:50 : _SetAuthMark Fail
16:42:50 : _SetAuthMark Ok : wAuthMark(65535)
16:42:51 : _DetachDLL Call
16:42:56 : _DetachDLL Call End
16:42:56 : Param : Path = C:\ProgramData\LGMOBILEAX\Phone\MS65910c_Develop.wdb
16:42:56 : Param : moduleDir =
16:42:56 : Param : waitTime = 0
16:42:56 : Param : UsbHighSpeed = 1
16:42:56 : Param : PhoneMode = 2
16:42:56 : Param : BinVersion = MS65910C_00
16:42:56 : Param : AuthMark = 65535
16:42:56 : Call fn_StartUpgrade
16:43:34 : 3GQCT : wParam = 100, lParam = 0
16:43:34 : Step : Upgrade Error error code = 0
16:43:34 : ResetStartInfo() Call
16:43:34 : _DetachDLL Call
16:43:39 : _DetachDLL Call End
16:43:39 : FreeLibrary Call
16:43:39 : FreeLibrary Call End
16:43:39 : ResetStartInfo() Call End
16:43:39 : 3GQCT : wParam = 100, lParam = 64
16:43:39 : Step : Upgrade Error error code = 64
16:43:39 : ===FINISHED===
Any ideas on what I could try to recover my phone? Thanks!!
Emergency Mode!!!
Emergency Mode!!!
Good luck to you!
Hey I've also encountered this problem which seems to be a soft brick on my T-mobile. My device is stuck rebooting. I have tried the above fix and it seems to work except comes up with the error WParam: 100 and LParam: 64 so I click ok and try to boot up and it is still soft-bricked. I really appreciate the help!!
There should be one final step added to the instructions: after a successful flash and bootup, a factory reset should be performed, otherwise any files that were copied to the system partition during the previous install will still be there (which means you're not really starting with a clean slate).
- Click the folder icon and choose the kdz file that UpTestEX_mod2_marwin.exe just made.
- Click Launch software update and enjoy!
That isn't required to unbrick (except in some cases). Besides some people are unbricking phones with important files they want/need back.
If the intention is to unroot for a warranty claim or something similar, people will want the device in a factory state. So maybe it should be an optional last stop in the guide.True, but the thread title is "Unbrick OR Unroot".If the intention is to unroot for a warranty claim or something similar, people will want the device in a factory state. So maybe it should be an optional last stop in the guide.
Just using LG tools I was able to un-brick my phone. I was unsuccessful with the steps and software provided through this guide. Kept getting errors no matter what I tried to do. But thanks anyway for your time. I learned a lot and I'm sure this could still be an option if LG tools don't work.
I just had this error as well. Disabling anti-virus (Avast) didn't help. I booted into a different install of Windows on the same laptop, this one with Avast disabled, and it worked fine. So if you're still having problems, try disabling your anti-virus, or even uninstalling it completely, or of course just try another computer.
I did also restore a CWM backup between boots, so I suppose it's possible that the flashing software is doing some kind of check to make sure some basic components are in place before doing the flash.
Hi, I keep getting this wparam=100 error also. Trying the tmobile kdz. I tried two different PCs, disabled the windows defender (otherwise no antivirus ), no luck. I did not have CWM backup so it's not an option. Are there other options to try ? btw, I did not root it or anything, it just stopped and when rebooting went into bootloop. What's the chance it's an hardware error so I should just move on ? Thanks for any suggestions.
I think others have fixed it by using another computer.did you fix this .. i have same problem![]()
