Well I'll make the first post in here to confirm that Motochopper works on the Metro variant of this phone as well as the others. I rooted mine in about 30 seconds, fastest and smoothest device root I've done so far.
If you choose to experiment with deleting them you should back them up with Titanium Backup first so you can put them back if needed.
Also with regard to Titanium Backup, it's important to note that its default backup location is on the internal storage (sd0) and not the external SD card.
I'll go that route.
I put the sd card from my Esteem in this one and TB recognized the backup on the card. Was able to restore the data from a couple of games.
Ive downloaded motochopper and the lg driver 3.10.1. Followed all instructions on hexamob. But it tells me "abd is not recognizedas internal or external command, operable program or batch file". Please help.
Just google for motochopper, it's readily available for download in several places along with tutorials and very easy to use. Just be sure you have the latest LG driver for your phone before proceeding, you can get it from the LG website.
Also be cautious about actually deleting system apps, doing so can sometimes cause problems or even brick the phone. Apps which are safe to remove will have an uninstall option in the app manager, for those that don't you can just disable them. Some of the built-in apps have a disable option in the app manager which you can use even without root. Those that don't have the option can be frozen with Titanium Backup after rooting.
Nevermind. I was running it straight from winrar instead of the extracted motochopper folder.
What version of titanium backup did u download?
Apparently the new OTA update that came out the week around Dec. 10 2013 broke motochopper root? Can someone confirm?
