Root [MetroPCS & T-Mobile] (WIP)Themes
MrGlowy
DISCLAIMER: WE ARE NOT HELD RESPONSIBLE FOR ANYTHING THAT HAPPENS TO YOUR PHONE AFTER FLASHING THESE. YOU HAVE BEEN WARNED.
Note: The apks used were from T-mobile firmware version B. If it matters.
Ok, now to the good stuff
Black and Blue:
Here is both of them in one zip Dialer_Sys_UI.zip - 12.77 MB(Thanks AA!)
SystemUI:
final_System.zip - 4.18 MB
Dialer: Dialer.zip - 9.20 MB
All credit goes to Android Addict over from Unleashed PrePaids - Unleash the Power of Your Prepaid Phone!!!
This is what we have so far. I will try to work on them a bit more. I will be busy this week so I can't promise anything.
From the man himself (AA)
There was a new battery icon added and we also added 1% increments to the battery, both charging and not. Added a WiFi icon, changed the clock and date color. And there will be more added to this when MrGlowy has the time (I dropped this project so he took it over ;)).
Can you post the originals from metro C firmware? Ive lost my backup somehow when I did a factory reset. Great job on the blue theme!
They probably will work. Just look small. I haven't had much time to work on it due to school. But I'll take a look when I can.
would it be possible to do a version without the quick toggles and brightness slider.
I would like a close to stock jelly bean since there are no roms...
i have no idea what apps to use to do this or else i would give it a go.
