Root [MetroPCS / TMOBILE] [ROM] U.S. KitKat MINI 4.4.2
viperdink
Android Expert
[ROM] Kit Kat MINI 4.4.2
Kit Kat
[ROM]
Warning all READ:
* Your warranty is now void. We are not responsible for bricked devices or dead SD cards.
Please do some research if you have any concerns about features included in this ROM before flashing it!
YOU are choosing to make these modifications of your own free will *
Tested Installation - with zip copied to external sd
1. boot cwm or Twrp recovery
2. factory reset
3. wipe cashe partition
4. format system
5. install zip from external sdcard
6. go back, advance, power off
7. power on
8. enjoy customizing kk mini they way you want.
9. REROOT WITH TOWELROOT
KUDOS
MASTER CRAFTSMAN - HROARK13 -
DRJBLISS,KOUSH,PLAYFULGOD,AA,BARD,95,AB,GT,UPP,GEOHOT,CHAINFIRE,KURLYPUMAA
SUPERSU POWERD
- CHANGE LOG -
V-1
Initial
V-2
First update - Contacts and Data
V-3
Second update -
T_Mobile and MetroPCS APN Friendly
V-4
Third update - Refinement of function -
AVAILABLE ON UNLEASHED PREPAID
* Download THIS Link to Newest Release *
http://www.mediafire.com/download/hwtm7id9i8c568l/miniVOA.zip
Wipe all partitions and then install zip in your recovery .
Thats it.
> Hints in Post 2 <
Thank HROARK13 and support if you can!
USA.F6 KKUSA.F6 KK.VOA
viperdink out.
Contact:
Private Message KURLYPUMAA for Problems, Hints, Suggestions is quickest. He is the tester.
READING IS A FUNDAMENTAL REQUIREMENT
Be nice to our Devs and each other :)
Here is a look at my Daily Driver its all there.
https://www.mediafire.com/folder/2afdhp3m8k73c/3bpics
It's a link to a folder of my Screenshots.
Helpful Hints:
Using a PC makes it easier to Down Load , If you use your Phone, change you settings
to web or browser view in the browsers settings. This makes it easier to complete the
Captia Security Check. Reading all posts in a thread is always suggested .
I always Factory reset any ROMS I install first thing.
I always Format my System Partition between ROM installs.
Let it settle out a little when you first load them.
Always make a Backup and save it off the phone
To Enter into Recovery Hold " Home" key when starting up Phone.
It is Beta ware ! Use it or Loose it.
Betaware is a program or application that is still in the development and testing phase of software development, one of the stages that occurs before final release.
Betaware is a pre-release software or application given to a selected group of users so that they can try it under real conditions before the formal release to the public.
These beta versions have undergone alpha testing and almost look like the final product, yet as the testing
progresses and bugs are found, changes are made.
This helps to make the final release version bug-free.
Description;
It does look stock and is suttle, and does grow on you.
Check out the Home themes.
N/W Cameras,
The Boss " Horark13 " Which Brought F6 kk to the U.S. Has done a Good Thing Again.
http://androidforums.com/threads/kernerl-cm11-kk-with-ov5693-camera-support.879804/
Be Sure to thank Hroark13 for ALL his Help!
Thank you ALL for Trying this ROM.
Be Nice To Your Devs and each other.
:cool:
My phone won't show our play the
Captia...
i got it dling via PC ... nothing nice to say about captia
and whats the difference between this and lgf6_kk_beta5 ?
found out for myself so far only one crash from the install wizard...and home settings in settings causes a crash to homescreen..
other than that ..it's tiny...semi buttery ....and seems stable ..
without a pissing android...is that the stock boot animation?...kinda tiny
thank you for this...even more room saved
Finally'''' thanx' you should upload ....2A_rom too no issues what so ever.
I got dcn settings cleaned up... n rewriting new data tweaks i will upload soon
Finally... tether works fine... thanks for the DUN thing... it never crossed it my mind... i did tested with the other updates u send me n it wrks too. They are all good to go.:thumbup::thumbup::D:D:D:cool:
Thnx for shrinking it down!
For me contact's did not work forced closed even the dialer would not place call. Tethering would not work. Besides that rom was smooth. Its a shame it didn't work for me I did like the rom looking forward to tryin it out gain on your next update.
This ROM is awesome !! The only thing that I noticed but isnt a problem to me is that there's two different settings apps the one in the app drawer and the one in the notification bar (:
Did u formatted system,media data and cache in recovery before flashing?
This is for you &#127875;@@@ Viper... pull out CM under the mattress... :banghead: bro i know u hav it somewhere. Awesome as i like it but to tell u the true. Google hum... buaawk not for me.. :)
All 4roms are great.... :thumbup::thumbup::thumbup:
Does the camera work for devices that didn't have the camera working on CM11 and the other kitkat roms?
Yes I did.
Going to try again on the next update lets just hope that won't be a long wait.
This rom is fully fictional even though is in Beta level, myself and other Dev's had been testing this rom n some other ones the VIPERDING hav been putting together for all of us. Reason why we hav been testing n doing it in nondisclosure, its to bring the best for all of us , n not buried the Dev's work with this n that,,, of questions, like we all hav done with Dev's like Hroark13, Angablade, GT, Playfulgod, Sammy etc,ext,etc,, please follow instruction to the T, n u would hav a great Xperience ,,, of ur daly drive,:eek::eek::eek::D:D:D:thumbup::thumbup::thumbup::banghead::banghead::banghead::banghead::screwy::mad::mad::mad:
@@@Xieon,,, camera wrks,, i would recomend to use ICScamera from playstore , cus as taste,, wrks great i just like the UI of it i dont really like google's,,, but its a matter of taste
And u mean in rom,,,cus devices is different phs
I had problems and went back to "500 to 505"...
I had the phone all set with all my favorite apps......
And didn't realize till I was in the other side of town after midnight getting a burrito...
That I had exactly the same issues as "papadog" .....
No phone ,no contacts, no service,and crashing errors when I tried to get them working...
Ran sweet tho....lol...I'll wait and see what happens....
Besides excitement...I thought people that were in line to Dev for the F6...got in line for new phones...
Good job guys ...THANK YOU AGAIN
Its getting fix! Something simple... please. Remain seated.
Or D.I.Y
*Root explorer
*Got to system/app
*Move Contactsbin.apk , Contactsbin.odex to System/priv-app
*Make sure you hav wr-r-r permissions (644)
*Root Owner (change owner)
*Reboot
It should. Solved problem
