Root [MetroPCS] unbrick help?
Sorry I dont even know what that stuff is I dont know much about these things
Windows 7? windows 8? try using another usb port... make sure you are actually in download mode! make sure the phone is completely off, hold the volume up and connect it to the computer, this will put your phone in download mode
Want to point out that in some cases the antivirus and windows UAC can block the dll thinking it's a virus without you even knowing.
Start from the beginning by uninstalling all the unbrick tools from your PC then reboot. Then disable antivirus and UAC until you finish unbricking. Finally follow Trevor's instructions to reinstall everything to your PC.
HOLY CRAP U MIGHT JUST HAVE FIXED IT THERE IS A PROBLEM WITH THE DLL IT SAYS _setAuthMark Fail. Hopfully that is the problem thank you
This is wat it says
[R&D Test Tools Log File]
04:23:31 : Launching SW update
04:23:31 : Unpacking KDZ
04:25:03 : KDZ file extraced
04:25:28 : Files were extracted.
04:25:28 : LGMobileDL Load.
04:25:28 : Port = -1
04:25:28 : Connecting to phone
04:25:42 : Check Phone mode = 2
04:25:42 : Phone type check.......
04:25:44 : LGMobileDL.DLL Loading....
04:25:44 : _SetAuthMark Fail
04:25:44 : _SetAuthMark Ok : wAuthMark(65535)
04:25:44 : LoadLibrary Error(126)
04:25:46 : ===FINISHED===
Is there like some other dll file that I can download and replace the one thats not working:confused:
If u use the guide in motion's forum u would hav to put in the software as EMERGENCY./ // cdma Vm or somthinh like that. It would help just follow instructions there but with the mpcs500e or i KDZ.
Ughhhhhh still same problem
Im getting in my comp.... to see but just a quick. Thing
* put phone in download mode.
*Start KDZ software
*Conect Phone (wait until download or install drvs
* on type = CDMA-SMARTPHONE (VM)
*on phone mode= EMERGENCY
*** launch software update ""n wait
download KDZ again it may b broken...
O u never said cdma smartphone and u have a different kdz than me does it make any differences?
YESSSSSS is ur phone MPCS.. i hav mpcs500e and mpcs500i ... it longest is MPCS u are good if u hav TMO.. now we hav an issue
or u mean KDZ softhware?????:confused:
