yonniecarrizo
If you have a Samsung Galaxy light (SGH-T399) from metropcs and you want free and unlimited wifi hotspot, you must use these setting, but I am not responsible for any damage or problem on you phone, these setting are working great for me:
1.- you need to root you phone, go to http://androidforums.com/threads/recovery-team-win-recovery-twrp-2-7-0-0.836658/
2.- on you phone go to setting/more networks/Mobile networks/Access Point Names, create a new APN by touching at top right corner (+).
Name = T-Mobile
APN = fast.t-mobile.com
Proxy = Not set
Port = Not set
Username = Not set
Password = Not set
Server = Not set
MMSC = http://metropcs.mmsmvno.com/mms/wapenc
MMProxy = Not set
MMPort = 80
MCC = 310
MNC = 260
Autent type= Not set
APN type = Not set
APN protoc= IPv4
Bearer = Unspecified
Movile virtual network operator type= none
3.- download and install WIFI Tether Router by Fabio Grasso, I paid $2.50 with no regret (by the way, I do not get any reward for this app, you can try another one, but this one is working fine with me). after you install it, go to configure WIFI Router and apply this setting:
Network Name SSID = up to you
Encryption Type = wpa2-psk
WIFI Password = up to you
WIFI Channel = 1
Interface = wlan0
Method = 3 - HostApd
No Firmware Reload= unchecked
Drivers = nl80211
WIFI Mode = WIFI - G
HostApd Patch = check
LTE Tether Patch = check
Auto Disconnect WIFI = check
DHCP Setting = check on DNS Redirect
APN Setting = select the one you just created.
AND WALLAH, you are done.
Name = T-Mobile
Proxy = Not set
Port = Not set
Username = Not set
Password = Not set
Server = Not set
MMProxy = Not set
MMPort = 80
MCC = 310
MNC = 260
APN type = Not set
APN protoc= IPv4
WIFI Channel = 1
Interface = wlan0
Drivers = nl80211
