My memory card size is 8GB.
For clock work mod i will have to download ROM manager right!
Also tel me that i had installed a camera app called advanced camera which gave pretty impressive pictures than the default one. It kept starting with front camera afterward so i uninstalled it.
Now i installed it once again, but it is not starting. Home screen of that app comes & it closes by displaying, "unable to open.. . .... plz try again" lyk something.. .. .. .. ..
Well, what is the capacity of your SD card??
What I would do is format the sd card back to fat32, then boot in to recovery and use CWM to partition it properly. That will most probably solve your problem. (Partitioning with CWM is pretty easy) Just go to Advanced options and select Partition sd card.
Use the volume up/down buttons to move up and down, power button to select
work with the microphone hows the quality!
