Hello
Battery use details show
Cell Standby 41%
Battery used by cell radio
Use details
Time on 7h 19m 36s
But I have not switched on the radio from last many days, then why its showing "Battery used by cell radio"
Rgs
Ulfattu
Cell radio doesn't mean the FM Radio![]()
cell radio means -network or GSM .Then what does it mean if not FM radio
Try using astro Bluetooth module. download it from market.unable to share files via bluetooth with some devices...
had tried bluetooth file transfer also but of no use
plz. suggest some solution
^Use tubemate.
plz give me details about these build prop
persist.sys.multitouch=2 (i tried doing it 1/false but sys is still multitouch)
# This defines the min duration between two pointer event in ms
ro.min_pointer_dur=10 (tried this also with valus 60,100 bt no change)
# disable touch below 60 pixels
mot.proximity.distance=60 (dont what this is but tried and no diff)
i want to know what last two properties do exctly
Yup i think I know this
Multitouch =2 its a hardware property stating the number of touches the screen takes in or can take in at a single time ... try making it 3 or 4 and see if the device takes them ...
for the ro.min_pointer_dur=10
Pointer cancellation
When using touch or pen input, sometimes pointers on the screen can be canceled. For example, if your screen supports no more than two simultaneous touch points and you add a third finger to the screen, one of the other points will be canceled because the hardware cannot track three points. [http://msdn.microsoft.com/en-us/library/ie/hh673557(v=vs.85).aspx]
and
mot.proximity.distance=60 clearly states that it will consider any 2 touches to be 1 if you touch in a distance below 60 pixels
like two fingers you use to touch is not separated by 60 pixels they will be treated as one finger itself by the software
Hope that helps![]()
