Help Micromax A70 stuck at boot screen. Help!
Sag10
Hey all,
I have this new Micromax A70,
for some reason it's gone into Boot loops,
only the Micromax logo appears, it dosent go beyond it.
I've tried using the fast boot method,
but when I connect my phone to pc and press the Camera button,
it only shows that the battery is charging, and I've installed Android SDK also.
It's currently on the stock firmware, and stock rom.
I dont mind Rooting it, If i have to, but i need to fix this problem.
I've even tried all the combo's such as Vol Up+power etc...
still not working!
Please Help!
i know u tried fastboot method in wrong way
press camera button as tight(don't break it) as u can and then connect.
many of us were just pressing it lightly.
actually that camera button has two notches.
1st for autofocus and if u press more tighter u will feel another click.
we want second one.
so press that button hard and then insert usb(this has to b done in fone switched off state)
I tried, still not working!
This time around, I again tried pressing the Vol Down+Power
it worked, but only the exclamation mark around a triangle, with a droid
is appearing, nothing else, its stuck at that as well.
I assume u r not rooted n on stock recovery.
U can enter recovery by placing a finger on home button along with pressing power button.this method is shared by mmx itself.I hv no idea if it works..
But it's mentioned that there u can factory reset your phone.All data will be lost.
Before u do that i will advice to pull out the battery n keep it as for abt 2 min then reinsert the battery n try to power up normally.
But How it went into bootloop by itself?u must have done something!!!what u were doing before it went to bootloop??
hey do one thing first of all do u hav cwm installed b4 getting brick?? ..ok if yes then b calm n now press vol- button first now with that press power button also.. u will enter recovery mode from where u can factory reset now if you hav not installed cwm then jst press camera button tightly and then connect your phone with camera button holding to pc after all dis ur pc will show fastboot mode connected and u will get only blank screen and after that give commands for that read mr Akshay post or go to how to unbrick a70 thread u will definitely get solutions
Nope you are doing the fastboot method wrong way !
first install drivers for Micromax a70 !!--you might have forgotten this !
now completely turn off the device !
remove battery twice and then press and hold the camera button do not leave !
now insert the cable to pc and mobile phone
now change directory to your fastboot-windows saved directory
then type in fastboot devices
and your device will be there
personally i have tried to connect my device via adb but it has not connected to my mac EVEN once but fastboot works every time !!!! :)
Yup
you entered into recovery but as no custom recovery has been flashed you get the symbol ...
just follow my steps in previous post !
Hey all,
still not working!
Please Help!
switch off ur mobl...press down volume button then click power button...u will enter stock recovery & android logo should come...press camera button & few option will come...go to factory reset option by volume key...select factory reset option by power button...reboot when its done...
this should solve ur problem,I am in stock rom,I had done this...& to do this u don't need to do rooting...
now just click d camera button!!!!!!! ;) recovery opinions will come which includes factory reset opinion!!!!! to select click power button!!!!! :D
How do I install the drivers?
Ive seen the threads but when i Upzip the file,
and right click on "install",
it says that my system is not supported.
how will in install the drivers, if my phone isnt turning on in the first place?!
I have no Idea, my sister was using it,
she even complained that it switched off on its own sometimes,
then she came and told me that, it wasnt turning on!
First of it rarely switches off of its own unless you have done something with root folders !
more over sometimes it may take 10 mins even or more to start up just have to be patient !
also in case you are unable to boot recovery even try flashing using fastboot and regarding drivers i may not help as drivers are not needed for Mac and Linux...
Also, i have tried to boot in fastboot mode .... it says Android system recovery utility....there are four options--
1.reboot system now
2.apply sdcard:update.zip
3.wipe data/factory reset
4.wipe cache partition
what should i do???
1.reboot system now
what should i do???
That's not fastboot, it's recovery...have you checked CWM Recovery installation thread for instructions?
ya i have saw that...would it be good if i make a file "update.zip" on sdcard containing the recovery....
And, what option should i choose in "recovery utility"???? help me plz
i want my phone back....
1.reboot system now
what should i do???
select wipe data/factory reset....it will do factory reset which should solve ur problem :D
will doing "factory reset" solve the problem of framework-res.apk...i actually deleted the file and now i m stuck in the bootscreen.....plz help....
and how to get into "fastboot" mode....??? and the driver download link...
There is a thread regarding installing CWM recovery...it has how to boot into fastboot...
