Root Mikg 2.1+3.0 v2.56+2.57 Themes/Skins
3VOcrack
:DThought I would flash the link for the themes and skins for this ROM. Some may not know about it.:D
Main 2.1+3.0 theme/skins link on Mik's website. Try all the themes and skins you want. Some are not compatible with 2.56 yet, but the ones below I have tested and or use as working 2.56.
MikG v2.xx Themes
New Mik Orange Theme just for v2.56 (nice and just fresh)
[WIP][THEME] Nick1313 MikOrange Theme (Update 10/13/11))
Wired Theme (I use this with the Apple vs Android lightsaber Wallpaper apple vs android starwars - Google Search)
[THEME] Wired | MikG v2.5 | rev3.8 | 10/10/11
Blue glass 2.55 & 2.56 (nice looking)
[Theme] TW671 Blue Glass,Updates 10/12 See Post 2,3,4
Fuzion Theme 2.5 (works on 2.56)
(Theme) Fuzion version 0.5 [MikG 2.5x] 9/21/11
Mik Skins 15 count (I have the mik 2.1 skins and use the OBsensed skin with my current theme and wallpaper mentioned above)
[THEME/SKINS] GB SENSE 2.1 SKINZ
XDA Thread for Mik 2.56 themes. I haven't tried this link but they should work)
[SKIN][04.07.2011] Skins for HTC Sense 2.1 roms - xda-developers
Pink for the ladies 2.55 and 2.56
[THEME] MikG 2.55/2.56 Pink Theme for the Ladies!!
***Please add any other themes or skins to use that cant be found from the above links I provided***
***I did not make any of these, just wanted to post a central post for most themes and skins for this ROM. I hate finding a little here and a little there and combining with that over there. If you have mods, please share and post all links and findings***
i think that this post should be its own thread.
and thanx for putting them in one place. i hope yall will try some of these themes. all you need to do is wipe dlavik cache and cache and flash it from recovery. don't forget to make a nandroid backup.
[Theme]r3wireD for Mik 3D
(Theme) r3wireD for Mik 3D (Major Update 9/18/11)
[Theme]Honeycomb Mik3d
[Theme]Honeycomb Mik3d (Update 10/8/11 + Htc Keyboard+boot animation)
[Theme] 09/15/11 TW671 3D Blue Theme Beta V1.0
http://themikmik.com/showthread.php?8593-Theme-09-15-11-TW671-3D-Blue-Theme-Beta-V1.0
*Same as above i take no credit for these themes, just bringing them over from MiK's page....(I'm running the r3wireD theme, NIIIICE):D:D btw srry in advance if they are already in the above links....
Thanks. I stopped messing with 3d since no go on up dates. Im messing with MikG and Supersonic.
found that GB Skins doesnt flash for 2.57. Any others???
You don't flash skins. That zip file you download needs to be put on your SD card, then extract it with a file explorer like root explorer or es file manager. Then you will have individual apps, you now install these with the file manager you used to extract them with.
PS. Those same themes for Mik 3d can be found for the supersonic rom. Under roots roms - supersonic - themes and mods.
I guess I should add my keyboard to the list, though it should work on any rom sense or also.
PS. I changed my name and I'm autogeek over on themikmik.
Its based on the stock android keyboard gingerbread version. It comes with on the fly switchable themes. 5 to each keyboard, so there should be something for everyone there.
Remember you need to go into keyboard and language and check off themed GB keyboard before it will work (like any keyboard) it may also just install over any previous gingerbread keyboard you have, depending on how it was named.
http://themikmik.com/showthread.php?7541-(MOD)-Gingerbread-KB-w-theme-selector-8-6-11-updated
Please post question or suggestions in that thread as I wont be monitoring this.
Hmm... I should work on finishing an update I made... Been a while ha.
I will be posting a blue theme for mikg 2.58 tomorrow. It will when finished be more complete than my pink theme. I will be updating my pink theme for 2.58 also in the next day or so. Stay tuned!
