Root Minutes Checker: Virgin Mobile
I am working on "Virgin Mobile Minutes" and trying to fix any reported bugs (please send me an email) every couple of days. Newest version should be working fine - I think
You are the man!!!!!!, Thank you for the great app, everything working great on my end ;)
graboszczak,
Just noticed that the widget is cutting off at the bottom. Strange, I swear it displayed fine when I first installed it.
New version works for me now. Can you add the ability to move the app to the SD card? I don't have much memory on the phone and the latest update to the Google Play Store app is really killing my available RAM.
graboszczak,
Updated to version 1.14. Widget stopped working. Opened app and it crashed. Cleared data. Entered account credentials. App worked again, but it showed my minutes were 300/300 which isn't even close. Widget still wasn't working. Had to roll back to previous version.
graboszczak,
Same here. Widget blanked, and I had to log in again. Tried to reinstall widget and it keeps force closing, even after fixing permissions.
My apologies. I accidentally pushed corrupt version (1.14) to Google's play market but fixed it couple hours later. Most recent version should work fine.
Regarding widgets - to my best knowledge, android does not support widgets if you move the app to SD storage.
In the future, best way to report incorrect behavior is to send email directly to me - my email should be available on the market. I do not visit forums that often but will definitely respond to all emails promptly.
Marcin G.
Vigrin Mobile Minutes (checker app)
