Familyguy1
Thought it would be best to make a thread separate from the original MIUI one just so we don't clutter it up.
And I also need help...I am on CM7 and want to switch.
Ok so I have the latest version (2.0) and plan to flash it. I am currently running Clockwork Recovery (not sure what version, it is old though) .
What's the basic straightforward way of getting this onto the phone and flashing it?
Radios : which one is the newest? I looked into the Radios thread but was unsure of what to use( MR 2.5 or GB? or...? Also with radios, how do you install it?
Finally onto MIUI: full wipe correct?
Thanks! And I think this thread will be helpful to others.
