Root MIUI port?
therad1
Hey PG and other devs for Esteem...now that you have source is there any way to port this over, it would be awesome to run some AOSP on the Esteem! :D
Hey PG and other devs for Esteem...now that you have source is there any way to port this over, it would be awesome to run some ASOP on the Esteem! :D
stock is as much AOSP as MIUI is. I wont be doing it, but doesnt mean sum1 else wont ;)
Thing is CM7 (as its what MIUI is built off of!) would need to be ported first b4 you could patch it with the MIUI files. ;)
ok, thanks PG...I'll keep my fingers crossed on someone trying it! How about it all you "young minded" code readers! The first to do it will be a hero in this forum for sure!
those look good...but Im a purist! I need framework! Times like these I wish I had the training and skills some of you guys have! Ill just have to sit back and be patient...:rolleyes:
remember guys "...if you build it, they will come."
I have the miui launcher on my phone i can give it to you if ya want. Its miui without framework problems it runs ok but i dont use it just too hard to reorganize my apps
