Root mm themes.
treyjones424
If anyone has a metamorph theme from another device that they want ported to the ally just reply with the theme name here and ill port it and upload here.
Sorry for digging up this old post... but...
Are you still offering to port themes? I would love to see a Miui theme for the ally :)
Ill work on the miui tonight. And ill make one that goes with raptor as well. I've been working on one. Alternate dark already works on 0.3
Good luck with the MIUI I have looked into making a theme based on it in the past, its quite tricky since MIUI is a complete overhaul and is so much different than vanilla android
Some of it does. The Icons don't change and the settings menu stays the same, as well as the power control widget. It's okay, I just thought it would be cool if the whole thing took to the change. I had the same problem with the R1 theme, I really liked the way the power control widget looked on 0.2, but it wouldn't change it in 0.3. It's weird how there are 2 res folders in framework and each of those have 2 drawable hdpi folders in them. It looks like there are 4 folders with the exact same thing on all of them. Can some of them go away?
That's not the themes fault it is google/lg's. The new software update vzb changed a lot of the paths that have to do with theming. In sort, vzb is trash.
purple passion is on its way. and my miui theme is galaxy based. it has the blue and black. check it out and let me know what you think.
I'm running velocity 4 do you have any good full themes for the Ally in red, black & red, or all black bkuz most themes I've come across just theme the notification bar & neglect the icons & widgets.
These type of modifications are very specific and not many people do them for releases. Your best bet is to learn how to theme yourself.
