Root MMS BACKside IHO
a5pe4
So it looks at first glance like I can't receive picture messages. Is this a commonly known problem or just a personal issue?
^ Definitely did not know that. Odd. But I actually got an MMS from a Sprint user. It says to download in my messages but nothing happens after 'downloading'
I don't think there are any issues with Sprint users. The only advice I can give is a full wipe/format and reflash the ROM and gapps. Test it out with someone on another network first, it should be working.
okay. having issues with this now. i'm using go sms. 8/31 build of backside. can send picture messages out but cannot receive them... and this was from someone with t-mobile.
poop!
If you change the user agent, you won't be able to send mms via VM. It's an issue with VM and a couple of carriers, we are at VM's mercy on this one.
I'm running Harmonia and don't any problems with MMS pictures. I've gotten and sent to every carrier around .. AT&T, Verizon, T-mobile, Sprint etc. The problem I have is with MMS video. I've been told that this is VM's problem and is SUPPOSED to be fixed (who knows when)
The dev of Harmonia, LeslieAnn, is the one who posted about the issues with AT&T. If you don't have any problems with VM<>AT&T, consider yourself lucky!
Hmm I'm afraid to switch to the 9/19 build because some of the problems people are having. That and I haven't done the research on how to update ROMs.
