Root mms no send
geekydude
Firmware e rooted MMS will not send I'm on 4g ummm using third party app but wont work on stock too
Airplane mode plus restarts. I delete the failing message and 4g arrows lit up while it was sending wasn't lot
Probably doesn't work because it's a 3rd party app. I use go sms but it but I have to use the default messaging to send mms.
He said it didn't work with the stock messaging app either.
Some last things before going to the metro store to try getting this resolved:
Make a backup onto your microsd with 2nd init recovery. Then factory reset and try sending a MMS.
If that doesn't work, try unbricking it and then try sending.
If after doing both of the above and it still doesn't work, take your phone to metropcs, and ask them to fix it. If they replace it, update to E firmware, reroot and restore your backup from your microsd card.
If they don't replace it, but do fix it, restore backup from microsd card after rerooting it.
So apparently the app was not allowing MMS and thus blocking stock MMS. After uninstall and then a restart it works. Looks like I'm stuck with LG unless I go to GO SMS which is slightly tempting.
