Root MMS not working
tooill
Member
i can receive picture messages but i cannot send, ived had this problem with all roms ived used, idr when it started.
at the momment im using VirusROM Kingdom REVOlution B1.3
if any1 has any ideas, plz throw them at me, thank you
Have you done a profile update, PRL update recently? Try that and see if that helps
handcent or stock messaging app? You make sure to do a full wipe, cache/dalvik wipe when flashing? Also try clearing data in settings for your messaging app. If the pics are too big, might want to make sure your messaging app is set to resize them if needed. Easy way to check that is by simply forwarding a pic that you have recieved, to yourself again. If you received it, you should be able to send it successfully.
I would also go to your send messages settings and see what the max size is set to for mms. Most I think default to 1mb or less while Evo can be set to 5mb. Make sure it is set to 5mb.
ok answering question time, ived done many dalvik and cache wipes so that cant be it, ived updated my PRLs too, so that also cant be it, i will try erasing my data for messaging
Im using Stock messaging app, for all the recent roms ived changed, and it hasnt worked in a long time. i will keep you posted
anymore ideas, throw at me plz and thx =]
This is probably a (very) stupid question, but... What's the name of the stock messaging app? I thought it was just Messenger or something along those lines, however I can't find it anywhere. Does Cyanogenmod do away with it completely?
I'm running nightly 99 and cannot receive MMS messages at all. I can send them, however. I've tried with both Handcent and GoSMS. I'm also unsure if having everything going through Google Voice is causing problems...
