MMS problems for Desire on O2
Hi again,
I can't get my Desire to send picture messages, I've trawled the web for settings and once of you has posted a helpful response but I still can't seem to get it working. Part of the problem is that O2 have no details on the handset yet (got it from CPW) so aren't brilliantly helpful.
Going into the handset under Settings>Wireless & Networks>Mobile Networks>Access Point Names - I get two options
1) O2 Mobile Web - this has a green 'Active' blob next to it, I messed with these settings and broke it temporarily but now working again
2) O2 MMS Prepay - I've changed this to match what should be the contract settings - I have the below set up but with no success:
APN: wap.o2.co.uk
Proxy:<Not set>
Port: <Not set>
Username:o2wap
password:password
Server: <Not set>
MMSC:http://mmsc.mmc.o2.co.uk:8002
MMS proxy:193.113.200.195
MMS port: 9201 (or 8080)
MCC: 234
MNC: 10
Authentication Type:<Not set> (only have options for 'None';'CHAP', 'PAP' 'CHAP or PAP')
APN Type: mms
Anything on there leap at you as to what I might be doing wrong? Thanks in advance.
Setting look the same as mine.
I would reset your phone to factory and choose O2 Prepay when asked at startup.
Give that a go.
Guess you've tried turning the phone on and off again. Maybe call O2 directly and just ask for their MMS settings?
EDIT: Wozza got in a reply, don't do a factory reset!!!!!!!
Hi again,
APN: wap.o2.co.uk
Proxy:<Not set>
Port: <Not set>
Username:o2wap
password:password
Server: <Not set>
MCC: 234
MNC: 10
APN Type: mms
Has anybody had any luck with picture msg yet.
I am on the simplicity o2 sim, and have used the setting above
(after modifying the mmc.o2 > mms.o2).
I cant send picture msg, but i can receive them, using the above settings.
set up using postpay
Stumped
I have had two picture messages not been recieved. However since then the ones sent have. Both were to a T-Mobile network. However my dad sent me one from his iPhone to me and I got it fine. He is on O2. I chose the O2 PostPay option when setting my phone up.
I might try sending a few tomorrow and see if it works. I'm on a normal contract. However I think if you have just started a new contract and SIM ring O2 up and get them to activate MMS and mobile Internet on your account. I have had to do this when changing SIM cards.
So,
i have just been told by the people i have sent pictures msg too, that they received them ok,
Thats all good, but the problem is, when you click on the msg in my sms application, its still showing as a pending msg, with the little clock next to the piccy.
Very confusing.
I have sent an email to o2 for an explanation
I can send and recieve mms fine with o2. Your settings are different from mine, of the top of my head, I know that I have 8080 on mms port. Sod it, here's what I got.
Name o2 MMS
apn wap.o2.co.uk
proxy http://wap.o2.co.uk
port9201
username o2wap
password password
server (as you got for mmsc)
mmsc (same as what you got)
mms proxy (same as what you got)
mms port 8080
mms protocol wap 2.0
the rest is the same as you got
I've also got o2 mobile web apn
and the second apn I got is o2mms postpay
so I have 3 apns
text to 2020 didn't work for me as I got an iPhone sim and they wouldn't allow it! So I had to hunt the settings down long and hard I hasten to add. But nows all good. Have you sent your self an mms?
Let me know if it works for you and I'll know if I can delete the third apn that I might not need!
Name o2 MMS
apn wap.o2.co.uk
proxy Wifi Homepage New
port9201
username o2wap
password password
mms port 8080
so I have 3 apns
Yep,
I put in the additional information, and it worked ok, received the mms ok.
But, same as before.
when you send a picture msg to yourself, or anybody else, they seem to get the msg ok, but when I go into the the message i have sent, it shows the little clock, in the rh corner, and when you highlight the messgage and view the report, it tells you the message is still *pending*, altho the recipient has received it.
This is what i get anyhow.
I managed to phone o2, qnd i was told, i may have a faulty sim.
UTTER RUBBISH.
I got the usual, take out your sim, take out your battery, wipe your sim with a small damp cloth.
Nothing the told me, made the slightest bit off difference, but i could have told them that in the first place.
I have used this sim, in 4 other phones, with no problem at all.
And when o2, doesnt have the answer, what you get told is.
SORRY, WE CURRENTLY DONT SUPPORT THAT MODEL AT THE MOMENT.
DOH !!!!
Taffysaint: I have the same settings as you except it's called O2 MMS Postpay, the MMSC address is http://mmsc.mms.o2.co.uk:8002, and the MMS port is 8080.
I'm on a standard O2 contract and bought the phone unlocked from CPW, it picked up the settings from my SIM and just works.
So,
Very confusing.
What phones do they have? Not all phones send back a report on O2 like the iPhone.
