asmallchild
Member
Has anyone else been unable to retrieve photos sent via MMS?
Did you make sure to turn WiFi off? MMS doesn't go through Wifi, only through 3G/4G mobile network.
there are hand off issues between the two radios. Here is some related info.
http://androidforums.com/verizon-galaxy-nexus/479142-pic-messaging-issues.html
http://androidforums.com/verizon-galaxy-nexus/478835-problems-picture-messing-wi-fi.html
http://androidforums.com/verizon-galaxy-nexus/485377-mms-sending-much-later.html
By that hand-off issue you mean phone turning on 3G/4G automatically to send/receive MMS when WiFi is on? I can't speak for that as I don't use MMS much.
But 3G to WiFi hand off seems to be fairly smooth when I move in and out of my WiFi zones.
yes but it seems to only be an issue if your in a low coverage area. For instance at my home i don't get good signal "according to all of the measurements not just the bars" and sometimes it takes a lot of effort to get a pic message to send out when i'm on my home wifi network. A lot of people have had issues with mms on this device. Also it's very sporadic. I haven't had it happen lately it just seems to happen whenever it wants to.
