Root Mobile Network State always disconnected
Problem started yesterday, was running CM 7 (newest one possible) and I couldn't use mobile data, only wifi. Switched over to Savaged-Zen mod (also newest one possible) and still having this issue. Even going into settings and turning on/off mobile data and airplane mode does not help. Any ideas??
I can make and receive calls. I cannot use apps that require mobile data like WHERE, or Weatherbug etc etc.
Where can I find the radio version? baseband is 2.15.00.07.28 if that helps
that does help and its likely your problem, the newest radio is 2.15.00.11.19. You need to flash the newest radios for those roms.
you can find them here
[ Radios ][ 5-6 ] All EVO Radio, WiMAX, PRI, NV & HBoot versions - xda-developers
Flash the 2.15.0011.19 and the wimax 27167 unless you are already on that one. Make a nand back up in recovery before flashing these.
PRI and NV dont so much matter except they will affect from what we can tell battery life mostly. If you have 1.77 or 1.90 its fine. Dont eff with hboot.
There are actually newer ones that came out around the time of the ginger sense leak, i suppose you could flash the "latest" combo if you wanted but I havent used those yet and wont till june sometime so i cant advise as far as that goes.
Most of your info is in settings/about phone somewhere just look around for pri and wimax and see if you have the latest
Bigger problem now, I went to wipe and reflash, well I accidently wiped off the SD card so now I have no back ups or info on the SC card. WTF do I do to fix this? I can only load bootloader/recovery.
If I manually take out the card, install a rom onto it, then reinstall into the phone, will I be able to load it and fix this problem???
sucks you have no back ups, hate doin stuff without a safety net :)
From now on always store a back up with WIMAX keys on your PC just in case...
cool glad we got you going again.
Keep a back up of sd card and a nandroid on your pc
You may be able to retrieve a deleted file...there are file recovery options out there if ya google but chances are it has already overwritten that blank space with something else and its lost and gone forever. Sorry dude, be careful and make back ups.
Enjoy cm7 with data :)
also use the cloud man lol
My shit is saved all over the netherwebs, flickr, dropbox, google, gdocs, gmail, titanium backup in dropbox, windows media cloud etc etc...
