Mobile toggle widget?
HTC has a Mobile Network Widget that comes with the phone. Long press your home screen, select add widget and look for settings. A list of available toggles will pop up including brightness, wifi, etc. Beautiful Widgets (1.99 in the market) also has one and I believe if you type in Mobile Network toggle in the market you'll find a few as well. I know CurveFish makes a set of toggles.
simple long press then choose widgets. scroll down to settings press then find mobile network and you have what you want.
damn you worm.
