Here's a 1% battery icon mod for the 11-6 Tickerguy CM7 build for anyone interested. And yes, I know you can just set the options in CyanogenMod to show just the percentage, but I like the icons with numbers better than just the numbers alone.
Thanks to Tickerguy and Isaac for getting the build going.
Instructions:
Download the appropriate Zip and flash in recovery over the 10/30 CM7 build.
There's 3 Zip Files--download the one with the icons you want:
cm7_11-19_batteryicon .zip
cm7_11-19_batteryicon-sprint.zip - same battery icon, but the Carrier Name is changed to "Sprint" for the ones that want it.
cm7_11-19_battery-icon_circle_green.zip
Instructions:
